メインコンテンツにスキップ
2017年に発売されたAppleの第3世代スマートウォッチです。オプションで通信機能が付いています。
197回答 すべてを表示
Apple Watch series 3 no touch after screen replacement
I recently replaced the screen on my Apple Watch series 3 Nike + edition. The screen comes on and the buttons work but there is no reaction from the device when I touch the screen. I have tried force restarting it dozens of times and it has changed nothing. The old broken screen does not work at all so I believe that trying to use the old digitizer will not work. Anyone have any ideas?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
Sounds like either the display assembly was defective or the cable connection from the SIP was not fully inserted and latched or was damaged.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
I have tried reseating the cables a couple of times and that hasn't changed anything, unfortunately, so I am beginning to wonder if there is another component that might be damaged or if the unit is now useless
さんによる
I went back and tried your solution and to my surprise, it worked! I can't believe it was that simple of a solution, thank you!
さんによる
What exactly was the solution? @Blake Russell
さんによる
@chi.areadj - Either the cable was not fulled inserted or the display unit was defective.
さんによる
コメントを追加
Blake what was it that you did exactly? I am having the same problem…I can’t get touch to work. The touch cable appears to be seated into the connector…I’m stumped
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi Jerrod, did you ever resolve the problem with your watch? I have the same issue.
さんによる
コメントを追加
For me the solution was update the firmware and after the touchscreen start to work fine.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I purchased one of these sapphire screens for series 3. Screen works but in constant restore loop. Firmware upgrade fails each time also
さんによる
コメントを追加
回答を追加する
Blake Russell さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 20
過去 30 日: 81
今までの合計 3,998
