メインコンテンツにスキップ
iPhoneを自分で修理するために必要なものはすべて揃っています!最新のiPhone 15から、2007年に発売された初代iPhone 2Gまで、iFixitにはすべてのiPhoneに対応する無料の修理ガイドと分解情報があります。
22回答 すべてを表示
digitizer dont fit or something?
i replaced the digitizer but after I had put him on seems like that is not 100% fit. They also stabbing the rubber a little off. I've tried everything but it does not really work. maybe i need to remove the rubber?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
How can i place a picture here? So you can see what the problem is
さんによる
コメントを追加
2件の回答
ベストアンサー
By it not fitting do you mean it doesn't sit flush with the back assembly? Make sure you don't have any stray screws left inside the iPhone. Sometimes they can get stuck to the adhesive on the LCD backplate or inside small gaps in the logic board.
Also depending on who you got the Digitiser Assembly from, sometimes they are manufactured poorly and the glass has not been moulded correctly. If there are no screws stopping the digitiser from sitting and it is the digitiser itself, take a picture of the fault and send it to the manufacturer to organise a refund or replacement part.
Hope this helps :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Well if it's sticking up from the rubber, you probably left some of the old adhesive on the chassis. Make sure you clean that plastic chasers off really good. Then use a new adheasive, preferably 3m, but super glue works I guess. The rubber on the chassis is fragile. If it's sticking up or loose, rip the loose part off, better yet, cut it off with a razor blade. Just be careful. Let me know if that doesn't help. A picture of the problem would help me help you a lot more too. :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ronald さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 646
