メインコンテンツにスキップ
Appleの2016年ラップトップラインアップの最新モデルは、プロフェッショナルユーザーを対象としています。 15インチ、2880 x 1800 Retinaディスプレイ、クアッドコアIntel Core i7、256 GB / 512 GB / 1 TB / 2TBストレージオプション、16 GB RAM、およびTouch Barを搭載したキーボードです。
265回答 すべてを表示
Why does my MacBook 15 inch 2016 keep restarting?
My macbook keeps restarting randomly, sometimes when it’s asleep. It stopped working recently and had to have the motherboard replaced but it still keeps restarting. I have tried everything including a full wipe and reset. It stopped restarting for awhile but now it’s doing it again.
Here’s what the report says:
panic(cpu 0 caller 0xffffff7f8e54e970): "UPSB(MacBookPro13,3): thunderbolt power on failed 0xffffffff\n"@/BuildRoot/Library/Caches/com.apple.xbs/Sources/IOPCIFamily/IOPCIFamily-370.0.2/IOPCIBridge.cpp:1396
Backtrace (CPU 0), Frame : Return Address
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Sadly, your logic board either still has a problem, or one of your Thunderbolt port assemblies has a short.
Carefully disconnect the thunderbolt port assembly one side at a time (using the working side for your power)
You also may want to double check your power adapter is it an Apple unit of other? Are you using the original Apple USB-C cord? Not all USB chargers are the same! And the cords are likewise not all the same!
Some 3rd party chargers use different signals to monitor their charge rate and the cords wire gage on the power feeds may not be heavy enough to carry the higher current.
The last variable is the AC power its self! Make sure you are using a properly grounded outlet and ideally a surge suppressor (I have a nice two port unit for travel) or better yet a UPS while at home.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Sebastian さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 9
過去 30 日: 9
今までの合計 991
