メインコンテンツにスキップ
MacBook Pro 16インチの解体情報と修理ガイドです。2019年11月に発売されました。モデル番号はA2141とEMC3347です。
210回答 すべてを表示
Airpods pro range got worse
Hello,
Until yesterday, I had a Macbook Pro 13” 2018. Paired to it, the Airpods Pro. I was very surprised that the headphones worked not only in the openspace-office, but also in the workshop which was at ±25m (air)distance and separated by a concrete wall. Today I switched to the new Macbook Pro 16”. The positive surprise from yesterday turned into a very negative one: As soon as I’m at a distance more than 10m from the notebook, the music cuts. Same application, same software configuration (Migration assistant), only new MBP. Does the new MBP have a much weaker bluetooth antenna, or “what the range” happens?
Thx in advance!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Just looking at the teardown between the 2019 16” and the 15” models you can see there is really no difference in the antennas
2019 MacBook Pro 16”
2019 MacBook Pro 15”
Looking at the logic boards we can see a slight difference! Light Blue marked chip Wi-Fi/Bluetooth module
2019 MacBook Pro 16” - 339S00610
2019 MacBook Pro 15” - 339S00458
While the chips them selves have different markings, as these are custom chip we just don’t know what’s different inside.
Both list WiFi 802.11ac & Bluetooth 5.0 support so I can’t see a reason to alter the WiFi/Bluetooth transceiver chip.
So… I would double check another system to see if you got a bad one. The antenna cables could be damaged or could have been connected incorrectly.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Hello, Dan
Thanks for your response. Today I was with both notebooks to the Apple Service. Showed them the phenomenon. Answer was “it’s normal that the range is 7-10m, as bluetooth is working at this distance”. I showed them that the old one is working at a much higher range and showed them your suggestion. They opened the new MBP16, checked antenna connection, said it’s correct, and again reassured me that the range should not be more than 7-10m. Therefore…it seems it’s the old MBP’s “fault” to wok at that big distance. And no, I havent been with it to Chernobyl :)
さんによる
With the 10.15.2 update (build 19C57), the problem seems to be patched and the range is the same as with the old MBP.
さんによる
コメントを追加
Running MacOS 10.15.6 and still have bluetooth range issues….
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
danms84 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 1,048
