メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
Loop mode after changing battery
Replaced my iPhone 7 battery yesterday. I’ve done this in the past with my old iPhone so I felt fairly confident. Followed directions and all seemed to go smooth. When powered back on, my phone is stuck in loop mode and won’t fully start up. Rechecked all my cables and all seem fine. After further investigation I realized my phone would fully start up and work if I left the home button cable unplugged. Home button obviously doesn’t work, but everything else works fine. Any ideas what my issue may be??
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
My phone charges up and works fine without the shorter home button cable plugged in (other than not having a home button). I’m actually using it right now. It just won’t start up when home button is hooked up. Does this point to an issue with the home button or is it possible that it will boot up if I leave it in loop mode for a while?
さんによる
コメントを追加
2件の回答
最も参考になった回答
From your case it would be either one of the following:
The home button flex cable on the home button itself has been torn. Extremely unlikely if the metal bracket for the home button was not removed from the screen.
The most likely cause is a microtear on the screen cable itself. It'll be the smaller cable specifically coming from the screen and not the front camera.
The part where it tears is behind the metal shield that goes on top of the back of the screen.
Hopefully just the screen needs to be replaced rather than the home button which if it is the latter would required to be replaced by an aftermarket one with no touch ID.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Ben is right. This is a common problem after removing and replacing the screen. If you leave it long enough it should boot and you can confirm.
さんによる
コメントを追加
Check the parts near the battery connector. Be sure that battery is charged or connect to battery connector properly.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
CHRISTRUSCH88 さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 27
今までの合計 203
