メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2012年11月2日に発売されたiPadの第四世代です。Wi-Fi, CDMAもしくはGSM モデルがあり、16、32、64GBの容量オプションがあります。
sleep/wake button doesn't work/ apps just loop when tryin to download
i recently bought an ipad 4th gen (A1458) second hand and noticed the screen had been replaced. i should have checked it thoroughly but didnt since it was a steal. when i got home i noticed sleep/wake didnt function like it supposed to but if i hold the power button i can still turn it off and the most weird thing i cant install any apps on to it i can live without the sleep/wake issue but why cant i install any apps i just get the loop as if to download but nothing happens.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Power buttons sounds fine to me, the problem is the CASE/DOOR/SMART-CASE Sensor, you can disable it on settings to stop detecting the CASE/DOOR/SMART-CASE, about the apps there is a lot of guys removing icloud on ipads make sure that the ipad has Serial Number, make sure that the serial number is the same on settings and on the housing. try reinstalling iOS with iTunes too.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
for some reason i dont have that option to disable the lock sensor, check also the serial both match. i have also restored in DFU mode and nothing
さんによる
コメントを追加
回答を追加する
CholoKiD92 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 102
