メインコンテンツにスキップ
2016年3月に発売されたSamsungの機種です。モデル番号はSM-G930Vです。
My phone only charges off laptop
My Galaxy S7 is almost brand new. I got it, and when I was doing some work I accidentally got a thorn bush seed in the charging port. Managed to dig it out but now it only charges off my laptop and wireless charger. It says there is a problem with the battery when connecting it to any fast charge cable, and it won’t do anything at all off normal USB. Data transfer also doesn’t work, the file simply gets corrupted when transferring it from the phone to a computer and vice versa. Any USB that fits tightly in the port won’t work, and any one that is loose is very finicky.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Sounds like some pins might’ve been bent when the seed was removed from your charging port. If some data pins are touching each other, this can cause the issues you have described.
Unfortunately the charging port replacement process for this phone is nearly impossible without factoring in a screen replacement as well. I recommend using wireless charging for this device to prevent further damage to the charging port.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Well it can be done by an experienced microsoldering technician. We use hot air to remove the old port and solder a new one on. There are videos on YouTube that show it can be done.
さんによる
@benjamen50 is this what you're referring to?
https://youtu.be/nzYmecOucgU
I've never seen it done for a Galaxy S7 but I suppose it's possible. Thanks for the info!
さんによる
Yep that's how I do it. I do it for the S6 to s7 edge and note 5 too.
さんによる
コメントを追加
回答を追加する
Shadow soul60 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 856
