メインコンテンツにスキップ
PowerBook G4 Aluminum laptops with 17" displays. Released by Apple in 2003.
171回答 すべてを表示
New battery charges but just makes fan run when turned on
17” PowerBook g4 with mod A1057 battery. Have run with power adapter for years with dead battery. Installed “refurbished “ battery which charged with PowerBook off but when I push the power button all that happens is the internal fan runs . This has occurred with two different batteries. Would like the portability returned.
Update (11/22/2019)
It has worked for years off the power adapter and still does. Wanting portability I purchased two batteries and they both do the same thing . I have reset the pmu and pram. For a few moments it ran on the battery once almost long enough to set the time and date, but then black screen. I noticed that the power adapter was blinking back and forth between green and orange for a moment if that means anything. I don’t know it there is a reset button anywhere.
I am wondering if there is any battery management on the battery itself or just in the computer, so I don’t know it the batteries are defective and I should return them or there is something amiss in the laptop.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Does it power on using adapter?
さんによる
コメントを追加
1 件の回答
Sounds more likely your PowerBooks logic board has a problem here.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lowell Northrop さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 34
