メインコンテンツにスキップ
The Mi 9 is a mid-range smartphone by Xiaomi which was released in February 2019. Featuring a 6.39" super AMOLED display, a main camera with 48 MP plus an ultrawide 16MP and a 12MP telephoto lens, an under-display fingerprint reader and a 3300 mAh battery with fast wireless charging.
36回答 すべてを表示
Turns greenish tint/yellow on low brightness water damage
Hi,so apparently my Mi 9 has a amoled screen…5 days before this happens,my phone got water damage and can't even turn on…after 3 days my phone starts working but no image/light appears to the screen even the screen is responsive to the touch
But now…it's became normal but there's a problem if I put on the low brightness…the BLACK and GREY color looks greenish/yellowish….If I turn off my phone…lcd looks like it didn't shut off the light…my amoled panel still looks like it is power on
Can this problem can be solved with cleaning the corrosion by ISO Alcohol?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
Hi @thatzlyfe ,
You’ve got nothing to lose by cleaning it using Isopropyl Alcohol 90%+ as it will not get better by itself.
Do not use “rubbing alcohol” as it is usually <70% IPA, can contain scents and is generally not as effective as purer IPA. If you have to use the rubbing alcohol check the label to verify the amount of IPA
It is better that you don’t try charging it or turning it on anymore and that you disconnect / remove the battery as soon as possible to limit any further damage caused by the corrosive effect of the impurities in the water, electricity and the electronic components combining. Unfortunately the Power button on a phone is not a power isolating button and there is always power available at various points on the systemboard
Here’s a link to the ifixit Mi 9 repair guides which may help. Also remember to unplug any flex cable connections on the systemboard and clean the ends of the cable and the connectors with IPA as well.
Here’s a link that may also help.
Electronics Water Damage.
If all this seems too daunting contact a reputable, professional mobile phone repair service, experienced in liquid damage repair and ask for a quote. The better ones who will try to fix it will have better equipment e.g. ultrasonic bath etc than the regular repairers or DIY’s.
If you decide to get it fixed or try to fix it yourself, do it sooner than later
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Clean on which parts?
さんによる
@thatzlyfe all of them. you will have to disassemble your phone and clean all the components as outlined by @jayeff
さんによる
コメントを追加
回答を追加する
Thatzlyfe さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 78
今までの合計 3,447
