Car vibrate at 70-90 km
My car vibrates at 70-90 km and once I cross 100 it become completely normal, I thought it might because if tires balancing but I got the balancing done and it still continues, does anyone know what’s the problem thanks
You likely have out of balance CV assembly
These are the symptoms of a bad or failing CV axle shaft assembly
このアンサーは役に立ちましたか?
I will have to check with my mechanic.
Jignesh Patel rotate your tires or change your tires. Have a good mechanic check your front end including the ball joints and tie rod ends.
このアンサーは役に立ちましたか?
I rotated the tires but still the same problem, in fact, I changed my all-season tires with Winter tires and still have the same problem.
過去 24時間: 1
過去 7 日: 3
過去 30 日: 10
今までの合計 243
Does the steering wheel also vibrate?
Dan さんによる
Yes I can feel it, the whole car vibrates
Jignesh Patel さんによる
Jignesh Patel yours the All Wheel drive model?
oldturkey03 さんによる
No fwd 2.4 litre engine
Jignesh Patel さんによる
