メインコンテンツにスキップ
The Huawei Honor 10 is an Android smartphone released in May 2018. It has a 5.84" LCD display, 4GB of RAM, a dual 24 and 16 MP main camera, a 24 MP selfie camera, and a front-mounted fingerprint sensor.
I have screen problem after water damaged honor 10 lite
hi everyone
i have honor 10 lite phone
it fell to water 2 weeks ago
i let it dry with cold air for 2 days
then i turn it on
the phone working fine but there is white colors and lines appears to the screen after 20 sec from booting the phone and it dissapper again if i turn the screen off and reappper after 20 sec if i turn the screen on
so please guide me to the solution
thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
Water went in my honor 10 lite but my screen is not working its not turning on what to do?
さんによる
@sufiyan ahmed
See the Chosen solution below
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi,
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
First do not turn on your phone and then you need to remove the battery as soon as possible from the phone to minimize further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ (available at electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you do have to use it check the label to verify the amount of IPA
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing a Honor 10 phone which may be of some help.
Huawei Honor 10
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
obaydah kh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 2,010
