メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2690回答 すべてを表示
Ambient Light Sensor Filter Replacement
Along the top of a black iPhone 6/6S/7/8 (and their plus equivalents) there is a small white sticker under the ambient light sensor that filters light. This only exists on the black screens. I always transfer it over when doing a repair, but the odd time the area where the original is damaged has either caused it to go missing or has torn it causing it useless.
Am I able to get a replacement for this small white piece of (seemingly) paper? Without it, an active phone call placed to the ear does not black out the screen - resulting in buttons being pushed on the screen during a call.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
I think you are getting confused with the ambient light sensor and the proximity sensor.
The proximity sensor is there to detect when the phone is up against your face, putting the screen to sleep.
The ambient light sensor is used to adjust the brightness of the screen in different lighting scenarios. This is the one that has the filter paper. I have never really noticed if this makes a difference if it is there or not on the black screens.
If you think the ambient light sensor is not working correctly due to the filter missing you could just cut a piece of filter paper to pop in there. I have heard of people using a white marker but I am not sure of the results.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Ok so if I have an iPhone 8 that the screen isn't locking while on a phone call (after the screen was replaced) would it be more likely that the proximity sensor isn't seated properly? I know the camera flex cable on the 8 is finickier to reset than the ones before it.
さんによる
コメントを追加
回答を追加する
Bill Shannon さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 596
