メインコンテンツにスキップ
2017年Appleは13インチMacBook Airに新Broadwell Intl Core i5プロセッサを搭載して登場させました。バッテリー寿命の改善とパフォーマンスがわずかに向上しました。
423回答 すべてを表示
Restoring via network recovery. Corrupted info. on recovery server?
Trying to restore operating system on Mac OS Sierra and using network recovery option. After it verifies it says “The installer information on the recovery server is damaged”. Top recommendation is to download the macOS Public Beta Access Utility. Is this still available and has anybody had any luck with this method? Any help is appriciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Looks like Apple failed to update the recovery server images! Apples certificate expired!! Here’s more If you've got an old macOS install image, it will probably stop working today
Here’s the needed image file How to upgrade to macOS Sierra Jump down to Step 4 for the download.
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
Chose to upgrade to newest compatible OS, Option-⌘-R on startup, instead of restoring and seem to have dodged a bullet. Thanks for the pointers, Dan.
さんによる
Yes, you are lucky! What are you running now? Did you bump it up to Catalina?
さんによる
@danj Yep, wiped drive and then updated to Catalina.
さんによる
@haroldcantlie is it safe to wipe up drive and then update to Catalina ?
さんによる
@Irshad Ahmed - Yes, you'll want to reformat the drive. But you should make a bootable OS installer thumb drive following this guide How to create a bootable macOS Catalina installer drive
さんによる
コメントを追加
shutdown iMac / hold option/command & R keys down on keyboard & restart the iMac.
go into MacOS Utilities / select Disk Utility / select the top HDD in the list on the left / CLick ERASE / then SHUTDOWN again / (repeat the same startup process) hold option/command & R keys down on keyboard & Turn on the power to the iMac WHILE holding the keys down until the MacOS Utilities comes back up. NEXT / select REINSTALL MacOS /continue… then follow the prompts and BE SURE to select the same HDD that you previously formatted before you restarted the iMac. .. this will download the new Catalina OS .. it will take a while… I just did this myself while on the phone with Apple Support… and it worked.
P.S. it's best if your iMac is plugged into a network jack and not on wifi .. but wifi will work just as well but a bit slower.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Harold さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 20,346
