メインコンテンツにスキップ
Repair guides and support for the laptop/tablet hybrid in the Toshiba Satellite Radius series released in 2014.
20回答 すべてを表示
help locating my jumper pads for bios
I bought a storage unit. Inside was a computer with a bios password. It's a Toshiba p55w-c5200. I'm trying to locate the jumper pads on the motherboard to reset the bios password. If anyone would be so kind to help it would be great.
New pics
Update (11/03/2019)
I have attached some pictures, is that ok? And thanks for responding. It's much appreciated.
@oldturkey03
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Just make a jumper on JRST2501 for 10 seconds, 100% working for Bios password reset. Regards.
さんによる
コメントを追加
4件の回答
ベストアンサー
@t12icky0 first off, it’s a Toshiba. That is another crazy Black Helicopter company that is absolutely paranoid about releasing any information that may help a DIY’er. They do not care about anyone else but corporate greed and love to use their legal team for intimidation of independent service centers and DIY enthusiasts. No help from them
With that out of the way remove your Ram first. Most common place for the reset jumper is under the memory modules. Second, we need a couple of clear complete motherboard pictures without the RAM
Update (11/03/2019)
Just seen something in your last picture. Looks like JRST2002. That should be the BIOS reset.
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
Yea, I thought that's what it was. I have tried putting a screwdriver to the middle pads and it hasn't helped. Is there a special trick to ding the pad reset? I've never Done this before but im pretty familiar with computers. Is it just using wire to link both pads together?
さんによる
@t12icky0 that's usually all you have to do. You did power it up.......
さんによる
Yes I used keys, screwdriver, and a micro usb to bridge them. Then I turned on the computer and it still shows the bios lock.
さんによる
@t12icky0 let's investigate and see what we can find out. Slim pickins' with Toshiba
さんによる
コメントを追加
You can use this website to generate a bios master password which is based off a hash code or serial that is usually displayed when the bios password is entered incorrectly 3 times:
https://bios-pw.org/
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks for this solution. It worked for me
You will see the JRST2501 right below the JRST2002
さんによる
コメントを追加
i just had to do it myself but yes 2501 the middle one is it . It does work ,try to have them on the pads before you turn them on and wait it was a good 5 to 10 seconds then shut off
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sean さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 22
今までの合計 1,714
