メインコンテンツにスキップ
Repair and support for Slinky Toys. A coiled spring made of metal and/or plastic.
How to untangle a slinky as fast as it got tangled
I know you can work the tangle to the end (normally). Mine is welded closed at the end, so that’s just moving the problem to a new part of the slinky… But also, it made me ask the question I’ve always wondered: What is the trick to UNDO the original tangle. After all, if it’s that quick to tangle, it must be undo-able in 1 slick little move…
Any ideas
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
4件の回答
最も参考になった回答
I've not met a person so majestic to rapidly undo the knot of a slinky. But I can tell you that my method of undoing slinkys are relatively easier.
I would suggest stretching it out carefully to see where the knot is in the first place.
Then if you want, you can slide your thumb slowly through the coil, aligning everything in place slowly working your way down to the knot.
And then once you make it to the knot, flip it or untangle it slowly as you work your way down, carefully pulling the overlays apart.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Mike De Butts depends on how it is tangled. Most common method is outlined on here
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
i love your name but get it ok here its goes. use a ruler
Update (12/01/2020)
22222222222222222222
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
So basically what I did is I Kept rotating the coil different ways and eventually it came undone…Took around 10 mins depending on how much it is tangled✨
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Mike De Butts さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 26
過去 30 日: 95
今までの合計 18,576
