メインコンテンツにスキップ
Apple's mobile device operating system.
14回答 すべてを表示
How to test proximity sensor on iOS 13.1.3
Hi,
I have repaired some phones now and have realized that the proximity sensor can’t be tested anymore with iOS 13.1.3 with the voice memo app. Apple have removed this function now.
Does anyone have an other quick and easy way to test the proximity without using any apps or have to connect the phone to any diagnostics program? And without having to call any one too.
It was so easy earlier with the voice memo test.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
You can use the raise to unlock / lift to wake feature, when the proximity sensor is blocked it should not let the screen automatically go on when you pickup the phone.
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
Thanks haven’t thought about that
さんによる
I'm not certain this is testing the proximity sensor. I notice when you pick up the (sensors covered) phone the screen does not stay black but will be dimly lit. I think that is the ambient light sensor, not the proximity sensor. Correct me if I'm wrong but shouldn't the screen go completely black for a successful proximity sensor test?
さんによる
I agree with Barbara. The method above tests the ambient light sensor.
These are the options that we previously used which no longer work on newer iOS versions and 13:
- Voice Memos
-Siri (place up to your ear and screen should go black, well it used to)
-Make a phone call (currently the only option we're still able to use but only when a sim is present)
It would be good to know if there is another no service required option out there.
さんによる
Yeah it is supposed to go black completely and stay black when you lift up the phone with the sensor removed. Guess that's out of the question.
さんによる
コメントを追加
回答を追加する
Kristian さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 38
今までの合計 3,199
