メインコンテンツにスキップ
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
60回答 すべてを表示
Charging port broken, how to replace it?
In short, title
a few months ago the charger on my Asus x555L started acting strangely, only charging when it was turned at a certain angle. now it refuses to charge entirely, and the charger will not stay secure in the port as the port is broken. how would I replace the port with a new one, thereby fixing the issue?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
1 件の回答
最も参考になった回答
The charger port is soldered onto the board meaning you’d need either a hot air rework station + soldering station to remove the port or a soldering iron station + solder sucker to remove the old solder to remove the old charger port.
A lot of the time these ports can actually be repaired without replacing by redoing the solder on these ports as seen in this video:
https://www.youtube.com/watch?v=qWXISqQh...
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
回答を追加する
stan_albatross さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 18
今までの合計 1,096
