メインコンテンツにスキップ
技術スペックは5.5 インチ、1440 x 2560ディスプレイ、指紋認証センサー、12 MPリアカメラです。
16回答 すべてを表示
New battery smelling sweet and fruity
I just received a brand new Huawei P10 Plus battery from here, and when I opened the packaging it had a very strong sweet smell. Now that I’ve removed the battery from the packaging, it still has a milder sweet smell to it. It seems to be mainly coming from a single corner of the battery. Is it still safe to use?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
It is safe to use. It seems that a lot of batteries that I've been buying in bulk from iPhones have a similar smell which is the smell of a brand new battery.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Hi @benjamen50
This is interesting.....
Saw some forums ... either use with caution or it is normal.
https://www.reddit.com/r/Multicopter/com...
Hopefully more people will share experiences like you.
さんによる
Usually it is OK unless it is visibly punctured.
If it is defective what will happen usually is that the battery will suddenly start to drain fast and in the end it will puff up.
So if it starts to suddenly drain fast dispose the battery (Warranty first if possible) and get it replaced.
さんによる
コメントを追加
回答を追加する
Jason Zhang さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 13
今までの合計 294
