Abeer Almansour actually this “doesn't make sense because it won’t be working for long enough to be overheating” does make sense. Your main processor only needs second before it goes to a thermal shutdown. The issue here is most likely related to the old YLOD.
You most likely have issues with your GPU processor. It is a flip chip design and the issue could be the solder bumps between the IC and the substrate. You could try the YLOD fix kit from ifixit PlayStation 3 Yellow Light of Death (YLOD) Fix Kit Combining this with a reflow with a heat gun may just complete a good repair. Check this guide for a better explanation. None of this is a permanent fix, nor is it a sure thing either. It all depends on the individual logic board and the damage to the solder joints as well as the chip itself I strongly suggest a reflow with this kit. Of course, a permanent fix would be a total reball. For a reball to be done, you will need the stencil, a rework machine as well as the proper reball temperature template, and a new processor. If you do not have those tools, you can not do a reball. In that case you need to find somebody that will do the repair for you. Yes, you do want to replace the thermal paste as well. Here is a very "quick and dirty" explanation of what causes most of the YLOD (and XBox RROD as well). It is not always a failure of the solder balls which connect the Flip Chip BGA package to the motherboard. It does happen and you can see why [ http://www.bunniestudios.com/blog/?p=223|on here] More commonly however is that the failure is due to the chip design itself.
As you can see the "bumps' are what actually connects the die to the substrate to make the chip complete. If these bumps fail the die does no longer make contact either he substrate and thus no contact with the circuit board. The chip has failed.
Here you can see the space where the bump has failed and no longer makes contact. We are talking microns of space here. So a bit of pressure on the top of the die potentially close the gap. Same with a reflow, it may allow some of material from the bump to reshape and starting to make contact again. The heating of cooling of the chip during use is what will eventually cause it to fail again.
1件のコメント
Those things overheat quick the fat’s power converter sits right over the cell processor and video card and since heat will rise, you end up with lots of trapped heat, or at least that is what it seems to me and my simple mind. They make external fans to aide with cooling, or if you want to keep it looking stock, I’ve seen mods online to boost the fans speed to cool down more than normal
Joseph Stratton さんによる
