Hi @waydeph
according the specifications,
UX301LA is having C32N1305 battery, which is not fully compatible with UX533F (voltage and capacity are different). It’s compatible with Zenbook UX301LA Zenbook UX301LA-C4003H Zenbook UX301LA4500. If you want to search for compatible battery, please disassemble your laptop and check manually, what’s written on it. When you will get a PN, you can easily search for the part on the Amazon, etc.
Note:
I’ve only found, that your laptop is compatible with 0B200-03120100, 0B20003120100, C41N1814, C41PPEH batteries. The original battery is supposed to be NASC41PPEH4800B4.
For the better know, check it manually.
depends does it fit the port for the battery and is it same voltage and mwh output?
Ayden Aldrich さんによる
Der Anschluß zum Netzteil wurde schon ersetzt.
wolfgang_kl さんによる
@Ayden Aldrich
wolfgang_kl さんによる
@Ayden Aldrich The connection to the power supply has already been replaced.
wolfgang_kl さんによる
