2017 display assembly compatibility.
Is the 2015 lcd assembly compatible with 2k 2017 Imac 21.5 ?
There are two versions of the 2015 21.5” iMacs the Non-Retina and the Retina 4K display version:
iMac 21.5" LCD Display Panel - Non-Retina - Apple P/N 661-02989 - LG Display: LM215WF3 (SD)(D5)
iMac 21.5" LCD Display Panel - Retina 4K - Apple P/N 661-02990 - LG Display: LM215UH1 (SD)(A1)
Now let’s look at the 2017 versions which likewise have two versions!:
iMac 21.5" LCD Display Panel - Non-Retina - Apple P/N 661-07321
iMac 21.5" LCD Display Panel - Retina 4K - Apple P/N 661-07322 - LG Display: LM215UH (SD)(B1)
From all indications the displays are not compatible either way.
このアンサーは役に立ちましたか?
I just installed a 2015 Non-Retina display on a 2017 Non-Retina imac and it works perfectly!
@pjvcc - The newer version display is a bit brighter.
過去 24時間: 1
過去 7 日: 1
過去 30 日: 7
今までの合計 690
