Model Jura A1 the brew group motor rotates continuously.
The brew group motor rotates continuously in the same direction.
I change the encoder, but the problem persists.
What could be the problem?
Did you have the brew group apart?
I had this issue when I took the brew group apart and didn’t get the lower plunger in all the way when I assembled.
このアンサーは役に立ちましたか?
I’m working on a Jura A1 when starting it cycles a few times and shots off what’s the problem ?
このアンサーは役に立ちましたか?
I had the same problem. I dissaembled the brew group, I disconnected all the the connectors on the motherboard, then i disassembled the brew motor. I checked the encoder who is connected to the brew motor, it’s sensible so verify the encoder is well assembled to the motor with the metal “spring”/connector. assemble the motor (assembled with encoder) then the brew group and try again.
このアンサーは役に立ちましたか?
What is the "Encoder" ? where it's located ? on the motherboard ? I have some electronics skills
I have this issue, motor rotate non stop after I unmounted this part and cleaned it. Will try your tips, thanks !
このアンサーは役に立ちましたか?
It’s the brew group had the same problem took apart the brew group lowered the inside, plunger one notch, and it worked
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 15
今までの合計 455
