メインコンテンツにスキップ
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
501回答 すべてを表示
Kenmore Washer Spin cycle noise
My 5 year old Kenmore washer model 110.27102310 has started making a very loud noise during the spin cycle.
The noise becomes louder at high spin speeds and sounds similar to that of an  aircraft with a propeller.
Would this sound be caused by the drum bearing going bad or another component?
Thank you,
Dave
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
If your Kenmore 110 Series Washing Machine is making strange noises, see the Kenmore 110 Series Washing Machine Makes Unusual Noises problem page for possible causes and solutions.
Check to see if you have a model descriptor something like a VMW etc. so we can check to see if there is a diagnostic program you can run. Yes, the tub bearing is a definite possibility. There are a few more things to check. things like:
bad transmission
worn out pulley
worn clutch lining
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
The Kenmore washer did display an error code in diagnostics mode.
The Error Code I read was F7 E6, which indicates a Motor fault.
So, It appears that I may have to replace the drive motor.
さんによる
コメントを追加
回答を追加する
Dave さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 7
今までの合計 361
