メインコンテンツにスキップ
2009年6月発売、2.66, 2.8, もしくは3.06 GHz Core 2 Duo Processor
300回答 すべてを表示
Installing 3 Operating Systems on my old MacBook Pro
Hello,
I am trying to install a copy of Windows 10 Pro I’ve purchased on my old MacBook Pro. However, I am currently using a patched version of Catalina and because of this I cannot boot into recovery mode and enable my computer to boot from my USB drive.
In a perfect world I would be able to run my Patched version of Catalina and Windows 10 only. Is there any way to “Allow booting from external media” without going into recovery?
At this point in my research I’m near concluding that I will have to install El Capitan (the latest OS my mac can handle) and partition the drive from there. If this is the case I am wondering if it is possible, and how, to run the native El Capitan, The patched Catalina, and Windows 10 off the same SSD. Let me know if you have any insight.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
You do realize that Catalina ONLY uses 64 bit applications?
さんによる
Is this just a condemnation of the capabilities of Catalina or does this affect me trying to install windows in some way?
さんによる
Keep in mind you've forced an older system to run something that was not tested by Apple at all and the hardware its self has limitations due to its architecture. Then you are expecting this already delicate config to go one step beyond trying to run Windows and I assume Linux.
Then we still have the issues of running a new OS (Catalina). Most of us have not installed it on supported systems and there are some issues running Windows that's just coming to light.
I would back off to Sierra (HFS+) and run BootCamp from it if Windows is important
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Are you are aware of using the Option key to get to the Startup manager? Mac startup key combinations
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I am, it displays the startup disks available.
さんによる
It does allow you to jump between different OS if they are setup correctly.
さんによる
コメントを追加
回答を追加する
Jacob Solano さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 69
