Fix a bent corner
What tool would you use to fix a bent corner on iPod touch 6th generation?
i have to replace the screen
There are many professional tools that will make the corner look perfect, such as the gTool iCorner or the PlierTek Corner repair pliers. If you’re doing this repair as a one-off, then any type of small smooth pliers (Like this one) will help bend the corner into the correct shape.
You should be able to get a basic pliers set at any local hardware or craft store.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 166
