メインコンテンツにスキップ
2017年4月に発売されたSamsungの新しいフラグシップのスマートフォン、Galaxy S8です。
304回答 すべてを表示
Battery drainage due to motherboard issue
My samsung galaxy s8 battery drains very fast,even in idle mode.
Customer care service says,its an issue of motherboard,battery replace will not solve this.
How can i fix or refresh motherboard without repairing it?
NB: phone overheats during charging.
Thanks in advance.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
@jnemon I am not sure who your Customer care service but you do want to start with a new battery first. You cannot proper troubleshoot without doing that. If that does not change anything you will have to troubleshoot the charging circuit. So start with a known-good point like a new battery
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi @jnemon
PMIC is a common failure for the Samsung S8 series. The typical failure will eventually result in the phone being completely drained and unable to turn on at all (its a good time for you to check the back-up settings).
Here is the replacement process for this chip: https://vimeo.com/274029552
If you aren’t comfortable with this repair, you can get the logic board replaced through any Samsung Authorized Service Provider. If your phone is still under warranty, there would be no cost associated with the replacement.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Life is BEAUTIFUL さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 1,635
