iPad is disabled connect to itunes on MacOS Catalina
Hi, I have a ipad with error message “iPad is disabled connect to itunes” but itunes is no more available on MacOS Catalina !
Can somebody please help me to restore this ipad ?
Check this out, it is still possible to restore an iDevice on Mac OS Catalina:
このアンサーは役に立ちましたか?
Hi, Thank you for your answers ;-)
I finally found the solution. iPad was managed by “apple configurator 2”, so I started the iPad in recovery mode and connect to “configurator 2”. Then click on “recovery”.
Best regards
このアンサーは役に立ちましたか?
hey! did u find out?? im having the same problem rn and i don’t know what to do lol
このアンサーは役に立ちましたか?
This is the official article on how to fix what you’re experiencing:
このアンサーは役に立ちましたか?
it didn't work :(
You know what? I read an article about this exact same problem!
So here is it: iPad is disabled connect to iPad
Basically, you hook up your iPad with your mac, and you will see a notification telling you to restore the iPad.
If not, the easiest solution is to use Joyoshare iPad System Recovery to restore the iPad without data loss.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 8,007
No one has yet found an answer. Apple sure stuffed getting ipad back alive
Walter Poole さんによる
