メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Repair information for the fall 2018 addition to the ASUS ROG Zephyrus lineup. This is a high-end gaming laptop in the thinnest frame for those specs at the time. Model number: GX531GS-AH76.
Over heating problem in zephyrus laptop
i have zephyrus gm501gs laptop and i think that something wrong with it’s over heating , when i choose silent mode for fans cpu temp max is 87 and no noise from fans, otherwise if i choose balanced or over boost mode temps will become over 95C and fans runs noisy, is that normal temps for that model ??
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Hello guys there is a new solution you can let it at 100% but you need to register proccesor boost mode
right click on battery --> power option--> advanced settings--> proccesor power managment --> proccesor boost mode : set it to disable instead of aggresive and your temp will automaticly decrease to 70°
If doesn't exist just download the registry called : proccesor boost mode
And after it you will find it in proccessor power managment
さんによる
Hi there
For everyone who has experienced similar challenges
Recently, I bought a used GX502GW. It turned out that within a few seconds, it heated up to about 90 degrees Celsius and ran Furmark at 12 fps. I tried a lot of software tweaks, but none solved the problems. It was delivered to Super Mac Service (located in Copenhagen, Denmark). There, it was cleaned inside, and new thermal paste was applied. The temperature then dropped to 50 degrees Celsius, and it now runs at around 80 fps.
さんによる
コメントを追加
2件の回答
ベストアンサー
Hi Mohammad,
the temperature of the CPU/GPU may be nearly around 90°C, but only in the full power state (playing some game on the ultra settings). If you are doing nothing on your laptop and it’s too hot, it may be full of dust or cooling paste can be out of date. I’m suggesting you disassemble your laptop and check your MB and remove all dust and also repaste your CPU - GPU.
If your laptop is still overheating after the replacement, it’s time to check patency of the heat tunnel. You can check it by blowing air into it.
For disassembly, check out this video, it is not the same type of laptop, but it’s the same principle! The specifics guide is here, but it’s not showing re-pasting CPU/GPU. According to me, it’s simple and you can do it without any guides.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
In idle both GPU/CPU temps are under 50C, but while playing games on ultra settings GPU reach 85-90C and CPU temps exceeds the 95C
さんによる
It is low overheating, do the re-pasting and then will be all Ok.
さんによる
Thanks for your answer>
Will try re-pasting but for now i just disabled the turbo boost for the CPU and temps are good but i lost chunk of FPS
さんによる
@Mohammad Aldababse
You are welcome :) Good luck and be careful during re-pasting.
さんによる
コメントを追加
最も参考になった回答
guys all you need to do in those asus laptop go to the power option and then to performance and then change advanced setting go to processor power management and set the processor maximum state for both to 99% this will decrease the cpu temp to 70 while playing
このアンサーは役に立ちましたか?
スコア 3
12 件のコメント:
@ aram keuteklian this is amazing! dropped my gaming temps from 90-95 to 65-70 now. 4800HS CPU here
さんによる
@ aram keuteklian thank you so much this helped tremendously!
さんによる
worked me for as well, thank you brother!
さんによる
I can't find this option when I go into power options. Is there another way to find it?
さんによる
Wow can’t believe how well this worked for me. Thanks so much bro, my computer went from hot plate to room temperature no joke. Thank you thank you thank you
さんによる
7件以上のコメントを表示
コメントを追加
回答を追加する
Mohammad Aldababse さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 32
今までの合計 35,012
