メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
touch is not working
My iPhone 7 fell off of my bed and now the touch screen doesn’t work. Is there a cable that just fell off or is it something bigger??
Update (10/08/2019)
thank you guys, I will try taking it apart again, I was messing in it a few weeks ago so I will check it out
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
I can think of a few troubleshooting options you can try. First you will need to get tools to take apart the phones display. But be careful the ribbon connecting the LCD to the motherboard. I that ribbon is ripped we don’t want to damage it any farther. The problem could be the ribbons {IF} that is the problem you got off the hook all you do replace them. If the ribbon is fine no tears or any thing indicating it has been damaged. Then the LCD and screen you will have to replace that.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi @mrmime
Try a simple hard reset first. Simply hold the POWER and VOL DOWN buttons for 10 seconds until the phone restarts.
If you are still having issues, it could be a damaged screen assembly. If you have opened the device before, it is possible that the screen connector came loose and a simple reconnect to the logic board will fix the problem.
Replace a screen compatible with iPhone 7. Includes all of the small parts preinstalled in the assembly. Features a 4.7 inch 750 x 1334 pixel IPS LCD Display, Front Glass Digitizer Panel, Front Camera Assembly, Earpiece Speaker, and LCD Shield Plate.の画像
製品
iPhone 7 Screen
$54.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Elias Williams さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 87
