メインコンテンツにスキップ
The entry-level version of the Inspiron 15 7000 gaming notebook from June 2017 lacks the higher-end hardware complement of its pricier siblings. The battery life puts many other laptops—gaming or not—to shame.
15回答 すべてを表示
little bug scrawled in between screen and protective layer!
Some little bug got in between screen and protective layer of my laptop’s display, it was crawling in the screen i though it is was on outside, so i tried to push it from screen, but i cant, because it was inside… the !&&*, and i accidentally pressed on it and it got stuck in screen looking like a black spot, how can i remove this, i can disassemble the screen but how can i remove it from the screen panel???
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi Vishal,
RIP BUG … anyway, you have to disassemble your laptop and then carefully disassemble your display. The display is really brittle, so be careful! You may damage it easily!
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I got the service manual from dell, and there is topics for how to remove the screen and display panel, but im not attempting it because im afraid i will damage the screen panel!!
The bug is not that big, i think around 0.1 cm on the screen!! but it still hurts my eyes, i always take good care of laptop since im developer, but this problem i feel hopeless!! i guess i have to take it to service center.
さんによる
You must be very careful. If you don't have any experineces with disassembling, put it into the local service shop. In the other case, proceed with caution :)
さんによる
コメントを追加
回答を追加する
Vishal Solanki さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 16
今までの合計 66
