Phone shuts down automatically.
It's working alright and out of the blue turns off. This happened multiple times.
Harshdeep Bagga there could be a multitude of reasons for it. Start with a new battery. If nothing else you will at least have a known-well starting point should further troubleshooting become necessary
このアンサーは役に立ちましたか?
There is nothing wrong with the battery.
Harshdeep Bagga how do you know the battery is ok?
If you are using a Mac, install Coconut Battery. It has an iOS button that will tell you your battery status when you plug your phone in via USB.
このアンサーは役に立ちましたか?
Software problems can cause an iPhone to shutdown randomly. Try closing other apps and close any open tabs you might have open in safari/other browsers.
If your iPhone’s storage is almost full, try deleting some info/apps off the device until you free up at least 10% of the total device storage.
It is a good idea as well to back-up and reset the device software to rule out any additional software problems.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 69
