I took it apart and did nothing
I took the cover off and did nothing on the inside. Now when I put the cover on, the screen doesn’t start or anything. I can barely see something but it’s not enough. I have no idea how I damage it or anything. Please help. I don’t want to pay 400 just to change the screen.
Update (10/02/2019)
この質問は役に立ちましたか?
5 件のコメント
So this is something that Apple does to screw you over.
When you take the back of the new models off, you actually tear a small cable that runs from the logic board to the plate. That’s apple’s way of seeing if the machine was tampered with by the user.
Unfortunately theres not much you can do. if youre in NY, i would recommend consulting with Louis Rossmann, but im unsure of any good repairmen in your area
EDIT: I have been informed that its just 2017 that does this. My bad. Thanks Tyler!
Shy さんによる
I don’t think this is it cause my laptop is 2014. It’s not really that newer. And I seen videos of it being taken apart and put together. Also, I called Louis Rossmann’s repair shop and asked for advice. They said that your information is wrong with MacBooks from whatever to 2017 doesn’t have a tampering device.
Tyler Young さんによる
@tyyoung95 Don't bother, it's just clueless BS :-/
arbaman さんによる
@arbaman Thanks for that bit of info, I thought it was all macbook airs
Shy さんによる
Yeah i see, a different board. I've uploaded a new image. Look at it above. Don't forget to disconnect the battery first.
Rav さんによる
