How to connect safari to the server
How can I connect. Safari to the server
It could be one of three things:
Wifi connectivity on the device, check that if it is either ethernet (by cable into your router) or if your wifi connection (without a cable) is on and working.
Your router is having problems connecting back to your wifi service provider. This means that it cannot talk to the servers there.
(This is the least likely one, but it could still happen.) Your wifi card has either gone bad, or one of the connections isn’t solid, meaning in that you won’t get good service, or even sometimes no service at all.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 6
過去 30 日: 14
今までの合計 76
Safari is a web browser app which needs a means to communicate via Ethernet or WiFi to the internet.
Can you give us your exact model and year.
Dan さんによる
it is a 21.5 late 2015
richardandjoyceott さんによる
