メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
The home button is not working
A buddy of mine asked me to fix his home button. I bought a new home button knowing that touch id wouldn’t work, after i replaced the home button it still didn’t work. Is there any connection that might be causing this? I went through the connections a few times and found nothing that would be causing the failure. It would be great if someone could help me with this, Thank you
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
If you purchased one of those few $ worth buttons you probably bought a purely cosmetic one, used only to literally fill the hole in the screen, that’s all. Unlike in previous iPhones the home button doesn’t have a click function, it’s a pressure sensor paired to the CPU, so either it’s original or it doesn’t work at all. There are in the market some workarounds from a couple chinese suppliers, one is a bluetooth paired button from JC, others are flat cable powered workarounds from JC or HX, that are known to be more reliable. That’s what you have to look for if you want to get back at least the return to home function.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Ok, thank you for your replies! I will look into the JC home button
さんによる
コメントを追加
Hi @mrmime
The iPhone 7 home button cannot be replaced because the “Menu” function is controlled by software through the Touch ID system.
To fix this issue, I recommend installing an original screen on the iPhone and taking it to Apple for a screen replacement.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Elias Williams さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 72
