Can I dish-wash my keyboard?
I want to use cascade platinum and a dishwasher to clean my apple 2e keyboard.
what steps should I take
Is this safe?
And is so, can I do it with the motherboard?
Bobby Gunnels no you cannot. There are way to many parts in the keyboard that will be destroyed by the water and chemicals used. The best would be to disassemble the keyboard and clean it with some high-grade isopropyl alcohol. Now when it is disassembled you can clean all the plastic pieces however you want to just make sure that they are dry before disassembly. Same goes for the logic board (motherboard). Stay as far away from using (regular) water as you can.
Check on something like this for a good cleaning (restoration)
このアンサーは役に立ちましたか?
I watch his videos all the time and he posted this https://www.youtube.com/watch?v=LlLDN2kn...
@Bobby Gunnels sure I get it and may have worked for him. The issue that will come and bite you are the deposits left by the water (minerals, dishwater detergent etc) all of this could lead to short circuits later on. Again, I would not do this but to each their own :-)
On the motherboard, I would remove it, use canned air to blow it off well. Then ultrasonic it in a solution of distilled water and Branson cleaner.
Sorry I don’t remember how we used to clean the keyboards. But remember, it’s not the water that shoots keyboards out, it’s the contaminates in non-distilled water that allow it to become conductive. Personally I clean my keyboards with a Q-tip dipped in a pure alcohol.
I do remember washing older keyboards, but it been a while and if I remember, I’ll chime back in.
このアンサーは役に立ちましたか?
Thanks for the reply
We were on vacatoin recently and my dog found a way to climb onto my desk and proceeded urinated all over the computer while i was gone and it dripped into the computer parts.
過去 24時間: 0
過去 7 日: 5
過去 30 日: 31
今までの合計 474
