Adhesive damaged in shipment
I just ordered and recieved my new battery and adhesive kit. The adhesive was damaged in the box. How do I contact to report this for a replacement?
Who did you buy the kit from
I would not be worry one bit about the adhesive. Just use a small bit of double adhessive table
The adhesive is there just to prevent the battery from moving
Once the battery is fine I not be worried about it
Much more important to have a hight quality battery
I never buy both the battery and adhessive together I would get a battery and use a small amount of double sided table
If it was a new battery you took off did you see how Apple glued the battery to the casing
This was not need for this
このアンサーは役に立ちましたか?
I bought it from iFixit.com and adhesive I am talking about is for the screen not the battery
Sorry but you did not mention that?? Hope this link helps you
@Kevin Thibodeaux Why do you need adhesive for an 7 plus screen You do not use adhesive when fitting a screen??
Your battery adhesive can technically be replaced with any tape strong enough to keep the battery in place. As for the screen bezel adhesive, this is only needed to preserve the “water resistance” of the iPhone. If this is not a concern, you can omit installing the new bezel adhesive. In my repair experience, I always install the kit when possible.
I would contact your supplier to see if a replacement can be sent out to you.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 36
