メインコンテンツにスキップ
モデル番号A1312 / Mid 2010 / 3.2 GHz Core i3もしくは2.8 & 3.6 GHz Core i5もしくは2.93 GHz Core i7, ID iMac11,3
382回答 すべてを表示
LCD Controller swap from LM270WQ1 SD E3 toLM270WQ1 SD E2
I have a screen that needs replacing so purchased a replacement screen but, discovered the controller board connections are different. However can I swap my controller from the LM270WQ1 SD E3 with the controller in the working lcd LM270WQ1 SD A2
thanks everyone in advanced
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Are you sure the T-CON board is good? Do you have a cracked LCD screen or is there another issue? You may find the problem was within the T-CON board not the LCD so you aren’t really fixing things.
I’ve never tried swapping the boards between different series so I’m not sure if it will even work. Have you tried talking to the seller of the wrong display or have any way of getting the correct one? I would hate to see you take such a risk when we just don’t know enough.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi Dan thanks for replying,
The original LCD has a cracked screen (long story) I have tried to contact the seller but have had no reply.
I know, well have found that the controller board can be swapped on other model screens, just wondered if the boards are changeable. The screen is identical in every way apart from the connectors on the board?
Thank you tho for taking your time to reply
Mentes :)
さんによる
コメントを追加
回答を追加する
mentes mehmet さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 275
