My ranger 2900 goes of if it falls forward on bracket what can this be
I’ve got a ranger 2900 cb it transmits ok and receives ok but if I knock it or it falls forward on the bracket it goes off what can this be please
Sounds exactly like you don’t have a good ground or power connection, it may be possible that the wire connector has a lose contact to the main board where it is soldered from the wire to the board but I think you have a lose connection first before digging into it. Add a bonding wire (ground) from the unit to the vehicle bypassing the hanger bracket and its ground as it is screwed to the vehicle, the more grounds the better.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 42
