メインコンテンツにスキップ
モデル番号はA1708/EMC 3164。2017年6月発売。このエントリーレベルのMacBook Proには伝統的なFunction Keyが搭載されています(OLED Touch Barの反対)。
563回答 すべてを表示
Is my 2017 MBP included with a slightly longer display flex cable?
In some forums there were people who said that Apple had corrected the flexgate problem by lengthening the flex display cable slightly in the 2017 MBP whose manufacturing date was in mid-2018, the same as in the MBP 2018/2019.
I don't know if the issue is true or not, and because I'm curious, I finally opened my 2017 MBP (normal condition), to see how the flex display cable works and just check the cable's condition ...
and this is what I found ...
the question is, is this the unit with the display cable slightly extended? because I have tried to open the lid to the fullest, but I do not see the cable under stress and do not touch the display board.
Update (09/17/2019)
This is the date of manufacture of my unit, which I saw in the battery application
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
4 件のコメント
Here's the extended warranty program: 13-inch MacBook Pro Display Backlight Service Program
You may need to ask for a warranty exception if your system is encountering this. Don't take no as the answer ask to speak to the manager and keep going! Some have had to fire off an email to big Tim to get it taken care of.
BUT! You need to have a failure! Until you have a problem Apple won't alter your system.
さんによる
The warranty program only applies to MBP 2016, does not apply to 2017 models
さんによる
Others have had the cable replaced when it has failed.
Again, you need to press them for a Warranty Exception! But only after the cable as failed.
さんによる
This is such a joke. My 2017 has the exact same problem.
さんによる
コメントを追加
1 件の回答
ベストアンサー
To start with your vid is not very helpful as its not tight enough to see the cable in question.
The proper way would be to look at the screen for the tell-tale signs. Do you see the stage-light effect at the bottom of your screen?
References:
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
there was no stage effect, my laptop was in normal condition, but I was afraid I would experience that problem
therefore, I opened the back cover of my laptop to see the condition of the cable, which was quite a bit of a cure for my concern because the cable was still in good condition
さんによる
Sadly, Apple won't fix things proactively!
さんによる
コメントを追加
回答を追加する
Rafly Prayogo さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 657
