メインコンテンツにスキップ
2011年初期のモデル。モデル番号はA1278 / 2.3 GHz i5 or 2.7 GHz i7 プロセッサー。
782回答 すべてを表示
What does this error code mean?
4SNS/1/40000000:VDOR-18.312
I’ve been dealing with this since I bought it and just dealt with it freezing once or twice a week. That was my fault. Now I’ve got my A+ cert and I want to see if it’s something I can handle without taking it to Apple. So far I’ve deciphered that it is related to the DC voltage sensor but I can’t find anything beyond that. Suggestions?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
VDOR = Logic Board - DC IN (Voltage) DC In
Your logic board and/or DC-In Board or Battery has an issue. The sensor is not able to measure the correct voltage on the logic board.
Can you give us some background and if anything was done to the system. Also, any other symptoms.
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
The only symptom is that it will freeze and have to be shut down manually about twice a week. It has been doing this since I bought it about 8 years ago. I’m the original owner and I’ve never made any upgrades to the hardware or had it serviced.
さんによる
First Apple won't fix this system as its on their Vintage and obsolete products list An independent repair shop might!
If you are going to try to fix this on your own you'll need to dig into the power circuitry tracing it out. You might just want to find a new logic board to replace yours.
さんによる
@danj I had a feeling that's what it was. Everything is square on the software side too. No rogue processes running or causing the shutdown. I've left it running for awhile without anything running and it would lockup. Nothing on the console that indicates something to cause it.
さんによる
@cptnez - Did you get your system fixed?
さんによる
Thanks for keeping in touch. I can't get a new battery until next month, I've heard that has been an issue. Will update asap
さんによる
1以上のコメントを表示
コメントを追加
I found this online thread where somebody got the same error code on their MacBook Pro. It pointed to a battery issue and some rouge app. Not sure it it’s what is happening here, but it might be helpful nonetheless.
https://forums.macrumors.com/threads/app...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Grant Tracey さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 470
