メインコンテンツにスキップ
1.83、2.0、2.1、 2.16、2.2、または2.4 GHzのいずれかのCore 2 Duoプロセッサーを搭載したModel A1181
1203回答 すべてを表示
I need help can a 2009 MacBook logic board fit into 2007 MacBook
Hello I have a 2007 MacBook a1181 black but I was just wondering can I swap the motherboard I bought a 2009 MacBook logic board and I have the other logic board that's 2007 out of the MacBook but is it possible to get the 2009 motherboard and use it in a 2007 MacBook
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Which 2009 MacBook is it? If it’s the A1181, it should work fine. If it’s the A1342, absolutely not.
このアンサーは役に立ちましたか?
スコア 0
6 件のコメント:
The A1181 has a square camera while the A1342 has a round camera. That's the easiest way to tell them apart
さんによる
What can I do with the motherboard then I only have just the motherboard
さんによる
@jj14378 I suppose you could check the ports, if there's two audio jacks then you have an A1181 board (compatible).
Also don't mind if it doesn't have the charging port, it's a seperate component you can take off your existing board and put on the replacement
さんによる
Update - just realized the 2009 boards have slightly different antenna connector locations. Well crap. I'm still really unsure if the antennas will work (so why accept my answer?)
さんによる
@ngs765 well what does accept mean and I didn't mean that sorry u want me to unaccept answer? I didn't mean to do that sorry
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Kenneth shawn さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 125
