How much it cost to replace screen
Hello ,
From the bottom little crack is there bar contain Logo MacBook Pro is it repairable separately or i need to replace whole screen , and how much it cost me?
Thanks
この質問は役に立ちましたか?
Hello ,
Thanks
この質問は役に立ちましたか?
The LCD is no longer separately replaceable from the entire display assembly as far as I know. You will need to replace the entire display assembly. Here’s the replacement part for the MacBook Pro you tagged in your post:
このアンサーは役に立ちましたか?
Thanks, Alot Bro thanks for the help :)
@Deepanshu Sharma anytime
@alexrobinson - Whoops! If you only damaged the logo chin plate you can replace that alone!
Here’s the part 15” MacBook Pro TB or Fn chin plate
And here’s the guide to put in on MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 8
過去 30 日: 11
今までの合計 3,158
