メインコンテンツにスキップ
The Nissan Xterra is an SUV that was manufactured and marketed by Nissan Motors across two generations, utilizing its Nissan F-Alpha platform shared with the Nissan Frontier pickup.
34回答 すべてを表示
vehicle cut off while driving and wont start
are there any safety devices in a 2002 Xterra that would shut off the engine that need to be reset or could the fuel pump be bad
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
選択されたソリューション
Let's start with the basics. Check your owner's manual for any fuel supply cut off switch. On Fords, they are often in the trunk of passenger footwell - the location of this will be located in the owner's manual. Once we've ruled that out as a cause, check the fuse for the fuel pump. If the fuse is good and getting voltage (you'll need a test light for this), move on to the fuel pump relay. Test the fuel pump relay by trying another relay in it's place. If this still doesn't fix it, check for power and ground in the harness that plugs into the fuel pump with the test light. If you get power and ground, then you've managed to isolate the issue to the fuel pump.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
i have got the same problem need solution
さんによる
コメントを追加
回答を追加する
kevin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 27
今までの合計 6,553
