メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPad Air 第2世代のセルラーモデル用修理ガイドです。
replace used touch+ glass screen
Can I replace touch screen + glass
to: iPad air 2, 16 GB wifi+4G - white color
destination iPad is A1567. I think It’s the same display, what do you think?
Color, memory size and cell/wifi wouldn't be dependent objects.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Every air 2 uses the same display. As long as you are experienced in removing Air 2 glass without cracking the glass it should work fine.
このアンサーは役に立ちましたか?
スコア 5
3 件のコメント:
With "removing Air 2 glass", are you referencing to only glass or to glass+touchscreen?
It's too hard to remove touch screen from glass ! I know It's necessary expensive and professional tools to join them again. I'm saying to replace the part which composed by both objects.
さんによる
@rickyleroy I'm sure @benjamen50 referred to the glass+touch assembly that is troublesome enough to be removed without damaging it. It will take lots of care, patience and right tools. Wish you luck :)
さんによる
I meant in terms of removing the whole screen assembly from the iPad housing.
Separating the glass from the LCD display is not what I meant.
Glass will sometimes inevitably have to be cracked if the housing is bent in some way that stops the screen from coming out after separating adhesive.
さんによる
コメントを追加
回答を追加する
Riccardo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 27
今までの合計 147
