メインコンテンツにスキップ
2017年9月に発売されました。モデル番号はA1863、A1905。GSM もしくはCDMA/容量は64か256GB/ゴールド、シルバーとスペースグレイ
873回答 すべてを表示
stuck on press home to upgrade
Hi, My touch ID and home button had been broke a while, ''''this was making my battery drain really quickly, i read online if you factory reset the device you can set up without touch ID and this can help the battery problem, But since doing this i set up the phone, connected to WiFi, and began to put my data from iCloud on, Because I did not use touvh ID i had to set up a passcode, I then was brought to a screen saying ‘press home to upgrade’ it shows the assistive touch button is on the side of the screen but I cannot use it, its as though it is frozen, I plugged into itunes and i cannot connect as it says enter passcode to use iphone but there is no way I can do this, I am just stuck at this screen:( PLEASE HELP
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
We use one of these for this exact problem they come in really handy.
Search for iphone x home button + audio jack. They work on the 7 & 8
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
The assistive touch button  can only show up if you set it up in settings
“My touch ID and home button had been broke a while, ''''this was making my battery drain really quickly
This cannot be the reason your battery draining quickly
If you change the Home button or it is damaged yout never be able to use the touch ID again has it is match (married) to the logic board A new home button will work has a Home button but you will have no touch ID
If you cannot enter you passcode then it is quite possible your screen is faulty
It is difficult to understand what information you are looking for by your question
Maybe you have more then one question
Can you please expand
このアンサーは役に立ちましたか?
スコア 0
6 件のコメント:
hi, thanks i know this is very vague, The screen is fine, I factory reset the device, I went to apple store yesterday and the guy at the genius bar said the battery draining could be from the touch ID as it is looking constantly for a fingerprint and cannot find it thus draining the battery as the chip underneath is faulty, this is no longer the main issue, My phone is stuck on a white screen that says press home to upgrade, I have set the language, selected a wifi network, and set a passcode and even set up my icloud account, I cannot press home as the button is completely broken, the box for the assistive touch is visible near the bottom right of my screen, But clicking it does nothing, I need to somehow get off this screen
さんによる
Power off the phone and power it up again If you cannot do then open the phone and disconnect the battery. Connecct the battery and power up see what happens then
さんによる
@edigitcom I am able to power off the phone, i had tried this and still at the same screen with nothing that can possibly be done
さんによる
When you say nothing can be done what do you mean
Can you open apps etc
さんによる
There is nothing like that, it is literally just a white screen and at the bottom in black is says 'press home to upgrade' and i cannot press home as my button does not work and the assistive touch icon is at the side of the screen and clicking it does nothing at all
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
callum.hesketh.7 さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 8
今までの合計 270
