Why is freshly ground coffee going all over inside machine and out?
My Saeco Vienna Plus, model SUP018m is still brewing coffee fine, but it is also spewing freshly ground coffee inside and outside of the machine - a lot of them. I took it for repair to a local guy and he couldn’t fix it, (but still charged me $150!) He thought the grinder mechanism might be cracked. Someone else I talked to wondered if it might be something wrong with the coffee doser or the chute leading from the grinder to the brew group. I would really be grateful if anyone could help me understand what is wrong and how to fix it. I am pretty handy and really don’t want to spend any more money on fixing this than need be. Thanks for your help.
3 件のコメント
Not at all familiar with your unit but you might want to have a look at the following to maybe get some disassembly or other ideas.
Saeco Vienna Sup 018
prop man さんによる
grinder saftey cap
Paul R Bokelman さんによる
Hi Debbie,
I have worked on and owned this machine and love it. I am having the same issue and I have not
found the solution! I have cleaned the grinder and chute/door area, washed and cleaned the brew
group, lubricated the brew group, checked the grinder position, changed grinder settings, in diagnostic
mode checked operation of brew group, grinder and door (hold middle start and steam right buttons while
turning on power button, select left or right volume knob for function. I have not yet found the solution.
I have several other machines however I do want to know the answer to the frustrating problem : )
If you find the answer please email me at Landrew3232@gmail.com, thank you.
Landru Landrew さんによる
