iPhone6s plus does Nothing after falling in water
Hello,
This morning I fell in saltwater with my iPhone in my pants. After 30 seconds I managed to get out of the water.
I tried powering it off, but it went off by itself.
1 hour later I opened the iPhone to remove water inside. It was quite wet. I used a hairdryer on low heat with a lot of distance to dry it. So I couldn’t over beat anything.
After that I let it sit outside in the sun for 1,5 hour.
Not seeing any water, I decided to put the phone back together and try turning it on. But it won’t turn on.
I tried replacing the battery but still it wouldn’t turn on.
Please tell me why the iPhone won’t turn on, or what else I can try to fix it.
Update (08/19/2019)
H jayeff,
You really know your stuff, thanks. I disassembled my iPhone, and found that the bottom of the logic board was affected a lot.
I already bought 90% isopropyl to put the logic board in.
I was wondering if I should put the rest of the phone also in the isopropyl, since it is also showing residues of salt and corrosion. Took out the battery already ofcourse.
Also so how long does it need to be in the isopropyl?
Please let me know and I will post the result soon.
この質問は役に立ちましたか?
