My Orange buttons on the remote RAV247 does not resppnd
How can I get the orange buttons on the Remote to work RAV247 even the AMP button does not respond
Hey, Dick. If it is a commonly used set of buttons on the remote, it might be that the conductive material on the back of the rubber contacts has worn down. This can be fixed by cleaning them with some Isopropyl Alcohol and applying a small drop of conductive paint, specifically designed for remote control repair. The conductive paint is available on Amazon. I hope this helps. Good luck! If that doesn’t fix the problem let me know.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 8
過去 30 日: 9
今までの合計 42
1件のコメント
If batterie(s) are OK, then most likely culprits are either the IR receiver on the stereo set or the IR transmitter on the remote. If you have a universal remote kicking around you may be able to use that to narrow down the problem.
prop man さんによる
