My washer stops at the drain and spin cycle
In the rubber hose (in the bigger diameter end of it) that connects the tub to the pump inlet, there's a floater ball. Do you know the function of this "floater" or if it can be removed? It seemed intended to prevent backflow into the tub from the drain....My washer stops at the drain and spin cycle and shows an "F" 06 error on the display and bipping for a few seconds. I removed the hose and found nothing big that could block the drain, except for the "ball".
この質問は役に立ちましたか?
