Water pressure switch and F35 code
Hello.
I have read all questions and answers about this issue. I have tested my pressure switch at the main control board and understand it should be putting out 0.383 V and increassing when the water fills the drum. Mine puts out 1.2V when empty. the power supply is at 5V as it should be.
My question is this: Because it’s putting out too much voltage, does this mean it’s the main control board that is broken? Online videos show that if the voltage is too low, the problem is the pressure switch that needs replacing but in my case the voltage is too high.
Thanks.
